Systems FAQ
Some questions get asked frequently on the Wall, and the Wallies usually have a lot of interesting and useful answers. We've collected some of the better ones here for you, and we'll be adding to this list often, so stop by again.
A good question that let to a great discussion on the Wall.
Read More
Can I add antifreeze to my heating system?
Read More
Why does the boiler manufacturer show it this way?
Read More
I want to use a buffer tank on this system, but how do I size it?
Read More
Who makes the best modulating-condensing boiler? Lots of opinions here.
Read More
How does a two-stage thermostat operate?
Read More
When getting hardwood ready for any floor it's common knowledge to have it sit in the space where it will be installed and let it adapt to the temperature and humidity levels. When asked, I always say wait two weeks before installing the floor. I'm at odds with a GC who says that three days is enough. I know it isnt. How long do you guys recommend?
Read More
What is ECM technology? Many motors run with this these days. What is it all about?
Read More
Who makes the best oil burner? I was curious, so I asked. Here's what the Wallies had to say.
Read More
What's the point of building a drop header for a steam boiler, and what does it look like?
Read More
There is a great thread on the Wall that addresses this issue.
Read More
How do you paint steam radiators? Several ways to get the job done, but the preference seems to be for powder coating.
Read More
What's the best sort of tank to use with a drain-back solar system?
Read More
Which is better, flat panels or evacuated tubes? Here's an interesting discussion between some very experienced people. Be sure to click on the links.
Read More
Suppose you live in a neighborhood with a Homeowners Association and you want to put a solar collector on your roof. How should you approach the Board? Here's a spirited discussion of that situation.
Read More
We just had a new steam boiler installed and I'd now like to get a thermostat that will make the boiler run at its best. What should I do?
Read More
Is it wise to use copper piping on a steam heating system?
Read More
Where can I find those pots that hold water on steam radiators?
Read More
What are the pros and cons of tankless water heaters?
Read More
