Security Seal Facebook Twitter Newsletter Sign-up
Radiant Hot-Water HeatingSubscribe to RSS feed
Oxygen-diffusion corrosion in radiant heating systems
Here's the straight scoop in plain-English Read More
PEX choices
Curious about the differences? Here's a plain-English explanation. Read More
PEX pipe makes noise
There is a great thread on the Wall that addresses this issue. Read More
Radiant heat and wood floors
You have be careful when working with wooden floors and radiant. Here's what you need to know. Read More
Radiant Out of Control
When the design is wrong, radiant can make you miserable. Read More
Radiant Roots
It all began in Levittown, NY. Read More
Wood floors and radiant heat
When getting hardwood ready for any floor it's common knowledge to have it sit in the space where it will be installed and let it adapt to the temperature and humidity levels. When asked, I always say wait two weeks before installing the floor. I'm at odds with a GC who says that three days is enough. I know it isnt. How long do you guys recommend? Read More
