Security Seal Facebook Twitter Newsletter Sign-up
Problems that plague ALL steam heating systemsSubscribe to RSS feed
The boiler is flooded
You are now reading a part of Dan Holohan's book, A Pocketful of Steam Problems (with solutions!) You can order the full text from Books & More. That way, you'll have HeatingHelp when you're on that next problem job! Read More
The boiler water is very dirty
The burner short-cycles
The burner shuts off on low water
The condensate- or boiler-feed pump doesn't behave as it should
The fuel bills are abnormally high
The pitch of the pipes is wrong
The radiators won't heat all the way across
The return lines are clogged
The system is losing water
The system is producing unwanted vacuum
The system takes a long time to heat
The water is bouncing up and down in the gauge glass
There's a bad odor coming from the system
There's no heat in certain areas of the building
There's too much heat in the building
There's water hammer in the system
You can't raise steam pressure on the gauge
