The Wall
Forum / THE MAIN WALL / Best steam trap testing equipment?
  • Post a Reply to this Thread
    Best steam trap testing equipment? (6 Posts)
  • Gasper Gasper @ 6:49 PM
    Contact this user
    anyone..............................?
  • Al Letellier Al Letellier @ 11:21 AM
    Contact this user
    steam trap tester
    Never seen a ultrasonic trap tester....In my book the only and best way to test a trap is to observe the discharge of the trap...that's why there should be a union directly downstream of the trap.
  • William Faust William Faust @ 2:41 PM
    Contact this user
    ultra-sonic trap testing aka \"survey\"
    I called a Tunstall distributor here in the Philadelphia, PA area. They charge $15 per trap. It makes more sense at that rate to replace the working parts or the whole trap.
  • larry larry @ 5:01 PM
    Contact this user
    Ultra sonic
    Pat: I Have two ultrasonics one that cost around $1500.00 nad one that cost $4500.00 with the price you can see there is a differance. The less expensive one is the one I use for steam traps which has a attachment for sound, used for air leaks and refigerant leak likewise it has a cone for vaccum leaks and then a metal probe that I use for trap testing. The other one is for medical gas leaks and vaccum line leaks I could use it on traps but that was not why we obtained it. It has a frequncey dail on it and a meter mode for aux. anolog and liniar sound then the frequincey can be adjusted from final band to about 10 kHz this is very good when working in a mechanical room and you need to find a leak with nosies all around you. you can look at UE Systems Inc. there web site is www.uesystems.com Larry Jci
  • larry larry @ 5:07 PM
    Contact this user
    Ultra sonic
    Pat: I Have two ultrasonics one that cost around $1500.00 and one that cost about $4500.00 with the price you can see there is a differance. The less expensive one is the one I use for steam traps which has a attachment for sound, and I used for air leaks and refigerant leak. Likewise, it has a cone to help pin point the leaks, and then a there is metal probe that I use for trap testing. The other one is for medical gas leaks and vaccum line leaks I could use it on traps but that was not why we obtained it. It has a frequncey dial on it and a meter mode for aux. anolog and liniar sound then the frequincey can be adjusted from final band to about 10 kHz this is very good when working in a mechanical room and you need to find a leak with nosies all around you. You can find them at UE Systems Inc. here is there web site www.uesystems.com Larry Jci
  • Gasper Gasper @ 10:18 AM
    Contact this user
    Actually my first post is "testing steam traps" but I meant to post a more specific heading. So this is it. I'm looking at investing in a good ultrasonic steam trap tester. Any suggestions on what type, model, where to purchase, etc? Also I'm what the experts think about this method of testing. Thank You
