The Wall
Forum / THE MAIN WALL / Cast Iron baseboard Rads push nipple removal
  • Post a Reply to this Thread
    Cast Iron baseboard Rads push nipple removal (3 Posts)
  • Dan C. Dan C. @ 8:16 PM
    Contact this user
    that's the method I use
    Doesn't take long . Just heat up the nipple and pull it out. I think thats the only way.
  • mike yozell mike yozell @ 9:06 PM
    Contact this user
    push nipple removal
    if you need to do a lot of them than go to an autobody parts store and purchase a "slide hammer " you can make a hook for the end and out pops the nipple mike
  • Jim Dawson Jim Dawson @ 11:18 AM
    Contact this user
    Cast Iron Baseboard Rad push nipple removal
    Does anyone know of a tool or faster way of removing the push nipples from the cast rads besides heating up the rad with a torch and grabbing with a vise grips. I'm trying to refit some rads together but the existing rads have either one or two nipples installed in same spot as the rads I'm fitting in. I was hopping not to trash them or replacing them. Thanks
