The Wall
Forum / THE MAIN WALL / dual temperature systems
  • Post a Reply to this Thread
    dual temperature systems (3 Posts)
  • BILL BILL @ 7:52 AM
    Contact this user
    DUAL TEMERATURE SYSTEMS
    WHAT IS THE PURPOSE OF HEAT PLATE EXCHANGERS IN A DUAL TEMPERATURE SYSTEM.
  • BILL BILL @ 7:58 AM
    Contact this user
    DUAL TEMP SYSTEMS
    THE DUAL TEMPERATUR SYSTEM IS A HOTWATER SYSTEM ,WITH TO HEAT PLATE EXCHANGERS DIVIDING THE CHILL WATER SYSTEM TO THE HOTWATER SYSTEM. WHAT IS THE PURPOSE OF THE PLATE EXCHANGERS.6 INCH CHILL WATER PIPING, 8 INCH HOT WATER MAIN.
  • Brad White Brad White @ 11:15 AM
    Contact this user
    A couple of possibilities
    The plate exchanger could be separating the two systems because of the source pressure (such as in a high-rise) or because the hot or chilled water has different solutions (glycol or no glycol, chemical treatment, etc. It could also be that the PHE is used for free cooling water-side economizer using condenser water for example. Without a diagram or more information it is just a guess. Traditionally, 2-pipe systems have 3-way diverting valves for change-over. Again, a diagram may help to get you a better answer.
    "If you do not know the answer, say, "I do not know the answer", and you will be right!"
    -Ernie White, my Dad
