Forum /
THE MAIN WALL /
SS Chimney liner
Post a Reply to this Thread
SS Chimney liner (8 Posts)
Any supply house your buying the boilers from will have or be able to get you a liner. To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional" -
Liner
We use Z Flex with no problems. I'm sure they have a supplier near you. -
50 Feet?
I'd be a little concerned with condensing the chimmney in this application. Are you doing boiler reset in this application? What stack temps do you expect to have? -
liners
I recommend you contact a local relining pro. They can assist you with the sizing, choice of alloy, brand, warranty, termination cap, and installation. An 8" is huge, esp. for such efficient equipment. Also, you may want to insulate this liner to minimize condensation. Probably will want AL 29-4C alloy instead of 316Ti. Type 321 is garbage and doesn't hold up. It is better suited for jet engine nozzles. -
Stainless chimney liner
I'm looking for an 8" x 50' stainless steel chimney liner.....anyone know a source in the northeast........thanks in advance -
Liner
I'm venting two Viessmann vitogas boilers..........sizing is correct, I'm looking for a flexible liner........ -
Just a question
What are you venting? 8" is pretty large. You might be able to downsize. -
Elmer's Pipe
Hi Mike, I've used this product before. They can custom roll up to 12" diameter. 50' shouldn't be a problem for them to make, but it will be pretty exciting to install. (Think Heavy) http://www.elmerspipe.com Paul B
