Forum /
THE MAIN WALL /
Luxpro thermostat
Post a Reply to this Thread
Luxpro thermostat (9 Posts)
Luxpro PSPA711
Anyone else having problems with the Luxpro PSPA711 thermostat. We have installed 100+ now having problems with several no heat calls and having to reset the thermostat. Also losing time or date. Called lux not having a problem? -
Luxpro PSPA711
I'm a new homeowner who has the Luxpro PSP511a model and have had the problem you describe. The unit was replaced and it still has the same problem occuring about once a week.
Battery
The only ones I've had with problems needed fresh batteries. But, you must have already done that. Nope, no problems. -
luxpro phased?
just a stab --is this anything to investigate maybe bad phasig = bab thermo-karma--nbc http://forums.invision.net/Attachment.cfm?phasing%2024v%20transf.pdf&CFApp=2&Attachment_ID=30907 -
luxpro phased?
just a stab --is this anything to investigate maybe bad phasing = bad thermo-karma-- http://forums.invision.net/Attachment.cfm?phasing%2024v%20transf.pdf&CFApp=2&Attachment_ID=30907 or maybe 110v.leakage. nbc -
Lux PSPA711 has a glitch
LuxPro PSPA711 has a new revision PSPA711A. I am certain they are aware of the Lux PSPA711 will freeze at random. Possible Defective Component or Software Glitch. They should recall these thermostat. I have seen where the heaters will not turn off due to the thermostat stuck in freeze loop mode. The temperature got extremely hot inside the house. -
Lot's of problems with Lux
Do yourself a favor and return it for something different. If the seller will not exchange it ask for a refund. Failing that, just pitch it and get something else. They are junk.
Que the old HeeHaw song...........
"If it weren't for bad Lux, I'd have no Lux at all......."
:) Sorry.....I couldn't resist...........This post was edited by an admin on October 3, 2010 9:49 PM. -
I was
holding back since I saw this post, but with Steve on board, I whole heartily concur. The only good Lux is the one not on YOUR job. Erratic operation, crap display, cheap.
I don't even use old ones for construction temp stats, they are that bad.
