The Wall
Forum / THE MAIN WALL / mectron 3m
  • Post a Reply to this Thread
    mectron 3m (6 Posts)
  • val val @ 6:14 PM
    Contact this user
    I have Bock 32E oil fired hot water heater the tank is 10yrs old ,the burner a riello mectron 3M needs the oil pump replaced.The burner is at least 15yrs old.Should i repair the oil pump or change to a indirect hot water heater and add zone on my boiler.What are the pros and cons is their any savings in the long run. thanks
  • val val @ 8:13 PM
    Contact this user
    HB Smith 8 series 4L with a riello 40 oil burner.The mectron 3M came off a Ford oil fired hot water heater that was leaking so I dont know how old the burner is.
  • Steamhead (in transit) Steamhead (in transit) @ 9:07 PM
    Contact this user
    The Smith 8 series
    is already tapped for an indirect, or at least the current versions are. Check the I$O manual to be sure. Is this a steam or hot-water system? To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"
  • UniR UniR @ 6:12 PM
    Contact this user
    hot water with a coil that is set up but valved off. Their is no problem adding another zone. I have 3 zones .I have taco 6 zone relay box.
  • Leo Leo @ 6:39 PM
    Contact this user
    A few variables
    Bock is one of the best water heaters but it still has more stand by losses than an indirect. The bock has it's own burner so an additional annual service and over time it will wear out and leak. Most indirects have lifetime warranties. The stand by losses are very low. The boiler will like having some heat now and then through the summer it will stay cleaner. I vote for the indirect. On the other hand Bock is one of the best and I bet you haven't had to put much money into the Riello, they are tough. Leo
  • Robert O'Brien Robert O'Brien @ 7:42 PM
    Contact this user
    What
    type of boiler?Is it maintaining temp?The Mectron was replaced by the F series in 1990,so it's at least that old To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"
