The Wall
Forum / A-C, Heat Pumps & Refrigeration / Pin Hole Leak in Trane Aluminum Condenser Coil
  • Post a Reply to this Thread
    Pin Hole Leak in Trane Aluminum Condenser Coil (16 Posts)
  • Bryan Bryan @ 8:05 AM
    Contact this user
    I agree
    the brazing thing is sort of hit or miss. Leak area is usually coated with oil.
  • MPF MPF @ 6:55 AM
    Contact this user
    Sta-brite
    has a flux for using their product on aluminum. Is this a new unit or an old one? Translation: They aren't making new units with alunminum coils again, are they? Chances are with that coil, if the leak is caused by any kind of corrosion, there will be others.
  • JOHNNYBOY123 JOHNNYBOY123 @ 3:21 PM
    Contact this user
    PIN HOLE LEAK IN TRANE COIL
    THERES A COMPANY CALLED DEVCON THAT MAKES A 2 PART EPOXY PART #19770.
    BE SURE TO WIRE BRUSH OR SCUFF UP THE AREA WITH SANDPAPER OR EMERY CLOTH. MAKE SURE THE UNIT IS COMPLETELY EMPTY WITH THE SCHRADER (BAD-SPELL) VALVES REMOVED. BE SURE THE REPAIR AREA IS FREE OF DIRT OR GREASE(ACETONE) IS GOOD FOR THAT. FOLLOW THE INSTRUCTIONS ON THE BOX AS FAR AS MIXING AND CURE TIMES. OTHERWISE U SHOULD BE GOOD TO GO!
    Contact this user
  • slapshot slapshot @ 11:33 PM
    Contact this user
    Trane Aluminum Cond Repair
    Trane sells a part for this exact very common leak. It is brazed to the copper line and then mechanically connected to the aluminum tubing. Surprised no one else in such a forum of "experts" was aware.
  • Techman Techman @ 5:17 AM
    Contact this user
    Leak
    I believe David Broome said that back on 8-6-08. Now that you proved yourself an "expert" ,you will be here to show more ?
  • unclejohn unclejohn @ 8:29 AM
    Contact this user
    I have repaired
    Alum. coils by cutting out the leak and usingĀ a flare union.
  • Harvey Harvey @ 10:34 AM
    Contact this user
    Trane leak
    We have used Super Seal on this in the past. It works great. READ THE INSTRUCTIONS AND DO WHAT IT SAYS. Harvey
  • Michael Wilson Michael Wilson @ 9:19 AM
    Contact this user
    I found a tiny, tiny pin hole leak in a Trane aluminum condenser coil, just past where the copper from the liquid line plugs into it. Is there any way to patch over this hole? I've asked a few guys and they've all said no. I figured I'd ask the experts here for the final word Thanks fellas, Mike
  • Bryan Bryan @ 10:16 AM
    Contact this user
    waiting
    for an answer. I run into this ocasionally and have not found a fix yet. You have come to the right place!
  • Techman Techman @ 10:35 AM
    Contact this user
    Alum-holes
    Hi Michael,there are two ways that I know of .One is AlSolder 500 by AllState,it's comes in a round container 3-4"h X 1 1/2" diameter.It has solder and flux in the container.But, BEWARE, DO NOT! apply the torch heat directly to the flux or the spot to be soldered.Read the instruction sheet!Indirect heat only! Then there is the epoxy method!Allow for curing time! Good Luck!Let me add,make sure there is zero pressure in the cond unit,and the suction and liquid lines are open to the atmosphere.The oil in the comp holds enough freon in it to be a pain in the "dupa",if there is not a pressure relief provided or pull a deep enough vacuume to remove the freon from the oil as per EPA
  • Ken D. Ken D. @ 10:49 PM
    Contact this user
    Aluminum
    Unless you are experienced at brazing aluminum, order a new coil (if it is still availiable).
  • Techman Techman @ 5:37 PM
    Contact this user
    Solder
    Brazing woun't work,SOLDERING will work .Just like a lot of other things in this wounderous profession WHERE else will you get the knowledge/skill if you don't give it a try? Cleaning the area is just part of TRYING to repair the cond unit.I for one will try that Super Seal stuff,what ever it is !
  • Eugene Silberstein Eugene Silberstein @ 12:03 PM
    Contact this user
    If all else fails
    If all else fails, give the Lokring system a try. You can mechanically join copper to copper, copper to aluminum, or aluminum to aluminum. The tubes can be different sizes as well.
    Eugene
  • N/A @ 9:22 PM
    leak
    at one time trane had a repair kit from copper to aluim most sixes were 3/8 used twice and never had a problem To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"
  • Jeff Lawrence Jeff Lawrence @ 8:02 AM
    Contact this user
    If there's one
    Others are soon to develop, from my experience. I've tried a version of the ALSolder500, but either do to misapplication or something, it didn't hold long. It did get the customer through the season (less than 5 weeks) and we replaced the system in early spring the next year. By no means is this the final word.
