The Wall
Forum / THE MAIN WALL / What the .....
  • Post a Reply to this Thread
    What the ..... (10 Posts)
  • Pringles Pringles @ 11:49 AM
    Contact this user
    What I really want to know
    Will brand "A" fittings and joining methods work with brand "B" tubing? Again I realize there could be liability and warranty issues just curious if it would work...thanks
  • Timco Timco @ 11:39 PM
    Contact this user
    what was yer' question? Tim
    Working on steam and hot-water systems isn't rocket science....it's actually much harder.
  • Pringles Pringles @ 11:47 PM
    Contact this user
    Question
    I asked if all brands of pex were created equal. I wanted to know if one brand of tubing was interchangeable with another. I specifically said that I understood there would be liability and warranty issues just wanted to know if pex was pex.
  • Timco Timco @ 12:11 AM
    Contact this user
    Short answer...yes. You just need to be sure you are using oxy barrier pex for heating and not for domestic...otherwise, it is interchangeable. Tim
  • N/A @ 1:02 PM
    with PEX... not PEX-AL... as long as they are rated to the same ASTM standard, fittings should be interchangable. PEX-AL is rated to a looser standard and is less forgiving. still, some interchange works.. just not always. Brand Y PEX fittings may NOT fit Brand Z manifolds and adapters, however, so fittings must match hardware.
  • Dan Holohan Dan Holohan @ 8:48 AM
    Contact this user
    Yesterday,
    we had an anonymous company repeatedly trying to do a marketing survey on the Wall about pex. I thought your post was part of that. If the anonymous company would like to contact me to discuss this, my email address is mailroom@heatinghelp.com
    Site Administrator
    dan@heatinghelp.com
    Hug your kids.
  • Pringles Pringles @ 11:31 PM
    Contact this user
    What the .....
    I posted a question a few hours ago and now it's gone! Was it something I said?
  • MW MW @ 12:21 AM
    Contact this user
    Is this to say that oxy barrier pex can't be used for potable water? The labeling on Rehau barrier pex indicates that it is suitable for potable use.
  • Timco Timco @ 12:37 AM
    Contact this user
    some makers may be approved, but the last batch of wirsbo He pex I bought said not for potable water right on it... Tim
  • Big Ed Big Ed @ 9:04 AM
    Contact this user
    Then you have
    A,B& C pex ......
    I have enough experience to know , that I dont know it all
