Post a Reply to this Thread
NEED SOME DIRECTION! (5 Posts)
Hot water or steam heat?
If water, do you have more than one circulator?
If one circulator, do you have zone valves or more than one thermostat?
CRANE SUNNYDAY 15
I HAVE NO HEAT IN THE BACK OF MY HOUSE, BUT THE FRONT OF THE HOUSE HAS NO PROBLEM GETTING HEAT. CAN THIS BE THAT I HAVE A BAD PUMP?
IT IS HOT WATER. THERE ARE TWO CIRCULATORS. ONE FOR THE BACK OF THE HOUSE AND 1 FOR THE FRONT. I HAVE TWO THERMOSTATS!
Jump the thermostat
Have you tried jumping the contacts on the thermostat to eliminate the possibility of a bad stat?
THE PROBLEM TURNED OUT BEING OF ALL THINGS AIR. I HAD A TECH PURGE THE SYSTEM AND NOW WE ARE COOKIN. THANKS FOR THE SUGGESTIONS GUYS! COOL SITE! HELPFUL
