The Wall
Forum / THE MAIN WALL / Polypropylene venting
  • Post a Reply to this Thread
    Polypropylene venting (15 Posts)
  • Derheatmeister Derheatmeister @ 9:55 AM
    Contact this user
    IPEX in Canada
    Check Ipex, they have a Polypropylene vent system,But i am not sure if it will be available since they no longer are serving the N American market needs. Also baxi luna has PP venting piping with adapters from 3 and 4 inch to metric . Or SS can be used.. Richard
  • Mike Dunn Mike Dunn @ 1:17 PM
    Contact this user
    Sorry
    to make a new thread on this, but who makes venting systems out of this material. (Polypropylene) Mike Dunn
  • Ron Gillen Ron Gillen @ 9:45 AM
    Contact this user
    Viessmann
    The Viessmann coaxial vent for the Vitodens is polypropylene pipe for the flue with an aluminum outer pipe. Only one I'm aware of.
  • N/A @ 12:10 PM
    Crown boiler
    Uses it for their bimini, it comes with the boiler but more is available if needed..http://www.crownboiler.com/
  • N/A @ 7:41 PM
    Burnham uses
    Polyproylene, I am sure they wpould be able to steer you to the manufacturer.
  • Mike Dunn Mike Dunn @ 9:01 AM
    Contact this user
    Tim
    I did not see any polypropylene venting on Burnham's website. Do you know if they are selling it with their new condensing boilers?
  • N/A @ 7:08 PM
    I dont believe they make
    a venting system but they make polypropylene pipe.....http://www.aquathermpipe.com/
  • kpc kpc @ 3:59 PM
    Contact this user
    boilers that....
    use it that I know of are... Burnham Alpine, Embassy Onex, Crown Bimini... This is their answer to PVC which the PVC guys state is not approved for venting boilers.
  • Doug Doug @ 4:23 PM
    Contact this user
    IPEX in Canada
    Since when are IPEX in Canada no longer are serving the N American market needs ? I heard about the Kitec water piping system recall, but that is only one small product line. Doug
  • Doug Doug @ 7:43 PM
    Contact this user
    Fire Rating Question
    I suspect that when it comes to plastic flue pipes, that is a little more to it than the temperature rating of the pipe. Fire rating of the pipe may also be necessary depending on local fire / building codes. I suspect this is why PVC has the plumbing / drainage market sewn up. Doug
  • N/A @ 10:55 AM
    Mike I am pretty
    sure they are it is the same stuff used in Europe. I am going down to my training center this afternoon and will check the unit I have as to what the material is. I will get back to you.
  • N/A @ 6:43 PM
    Mike I will e-mail
    Burnham.
  • N/A @ 7:57 PM
    I got the e-mail
    back as rejected by your server as being too large. Burnham does use polypropylene on there Freedom CM in a concentric vent.
  • Perry Perry @ 10:30 AM
    Contact this user
    Pay attention to the temperature ratings
    Not all polypropylene is created the same. I did some research and found the following offered: Standard polypropylene pipe & fittings: Rated for up to 180 F Available in many "plastic" catalogs and from many industrial suppliers. Laboratory Drain polypropylene $ fittings: Rated for up to 212 F Available from one company (the company that makes this system). Viessmann polypropylene boiler co-axial vent system: Rated for up to 248 F. You are looking for the 248 F (or similar) rating for a boiler vent system. Not sure where to find the 248 F (or similar) material - but as several other companies are offering co-axial vent systems someone must be making it. Perry
  • Derheatmeister Derheatmeister @ 10:44 AM
    Contact this user
    Perry..Yes
