Forum /
THE MAIN WALL /
Boiler circuit keeps tripping HELP!
Post a Reply to this Thread
Boiler circuit keeps tripping HELP! (6 Posts)
sounds like
you have a dead short... more details.. type of system, oil, gas, steam ,hw, boiler....etc -
Could this possibly be a new unit with an electronic oil primary? If it is look then to see if it is a 7148-1032 control. If it is then look to see if you see the sideways number 6 at the end of this number. If the answer is yes, then replace the Oil Primary control.
boiler circuit keeps tripping
If you amperage is close to or exceeding the rating of the breaker when the boiler starts up, you have a short somewhere. if you don't own a tool that measures amperage, switch out that breaker with another one of the same amperage rating in the panel. my guess is it will be 15 amps. If the boiler stays on and the breaker you moved somewhere else still trips, you have a defective breaker (one that trips when notheing is wrong with the load). breakers rarely fail but it is a possibility. a clamp on amp meter is an excellent tool for helping diagnose this type of problem. I think lowe's and home depot carry them. -
Boiler circuit keeps tripping, HELP!
I don't know if anyone else has had this problem. I am not sure if my boiler is short cycling, but I keep having to go to the fuse box a couple times a day, and turn the switch off and then on to get the boiler to fire up again. It seems like something is every so often, and I have to keep resetting it. Does anyone have any suggestions? -
If its an oil boiler check the starting amperage of the burner motor. Make sure the pump/motor shaft spins freely. I'd put my money on a bad burner motor. To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional""We see the world as WE are, not as IT is, because it is the "I" behind the EYE that does the seeing"
If this is a gas boiler with spark ignition I have run into this problem several times and it was the ignition control.
