Forum /
THE MAIN WALL /
grease buildup in drain
Post a Reply to this Thread
grease buildup in drain (9 Posts)
thanks, i'll give it a try--nbc -
Install...
a grease trap and have it cleaned on regular intervals. Is a grease trap not a code requirement in your area for this application/use? Lye (sodium hydroxide) based crystal drain cleaners should be effective on grease deposits however. -
yeah, g traps in restaurants
i thought they're national code -
I like this stuff
http://www.zepcommercial.com/products.asp?category=11 Any good supplyhouse will have a good non- acid cleaner. regular use is the key. -
Bio-Clean
has environmentally safe products for both residential and commercial application. A time proven product line -
Good to see you again, Mike!
How's things at M & A?..I see some of your guys coming bck up the road in the afternoons. -
Try this:
Natural Enviro 1000 - Grease Trap Solution... www.naturalenviro.com This is a bacterial type product.Does a fairly good job.No lye. I used to use Chloroben PT. don't know if it is still available or not. -
anyone had experience with some preventative procedures to alleviate grease build up in restaurant drains. i know that lye [sodium hydroxide] plus grease = soap, but does it work in drains?--nbc -
if it isn't
code in your area to have a grease trap on a commercial kitchen (e.g. restaurant, school, etc.) it should be. In any event, do install one -- at the very least on the dishwasher drain and any sinks used for cleaning or dishwashing. And Then Make Sure It Is Cleaned Out! Can't tell you how many grease traps I have inspected which were never cleaned out. You'll need a drain cleaner as the other guys have mentioned to get rid of the gook that's already there... Trust me: you'll have much better drains -- and the guys at the sewer plant will be very appreciative! Of course, if you have a septic tank, the guys who clean it will hate you, as they won't have to pump it so often!Jamie
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England.
Hoffman Equipped System (all original except boiler), Weil-McClain 580, 2.75 gph Carlin, Vapourstat 0.5 -- 6.0 ounces per square inch
