The Wall
Forum / THE MAIN WALL / 20 yr old Valiant question
  • Post a Reply to this Thread
    20 yr old Valiant question (6 Posts)
  • Saggs Saggs @ 6:30 AM
    Contact this user
    Hi, I have a customer w/ a 3 section Valiant oil boiler about 20 yrs old. It has had a small crusty weeping leak apparently where the supply flange bolts to the boiler block in the back. Its held on w/ 3 or 4 blots and has a gasket. Anyone familiar w/ this unit? I'm hesitant to start cranking the bolts out for fear of snapping somthing. Does anyone sell these parts or will I need to make my own gasket? Thx
  • Henry Roma Henry Roma @ 8:36 PM
    Contact this user
    Is it the supply flange or the return? They are both crosses with a flanged end. They sell parts for that boiler in Rhode Island. The place is called Smithfield Plumbing and Heating Supply. They usally have the flanges in stock in case you do break it. I can give you a phone number tomorrow when I get to the office.
  • Henry Roma Henry Roma @ 2:32 PM
    Contact this user
    SMITHFIELD SUPPLY 1 AUSTIN AVE SMITHFIELD PHONE# 1-401-949-0110 Here is where I get the parts for Valiant boilers. Hope this helps.
  • joel joel @ 8:29 AM
    Contact this user
    v
    You used to be able to buy those I don't know if you can get the gasket any more did you try doing a search Pinto Plumbing supply in Mass 508 473 7515 had a bunch at 1 time. IMHO it's 20 years old and you may snap something trying to fix it. With todays much better efficency from something like a Vitola they would be much better junking it.
  • Leo Leo @ 10:04 AM
    Contact this user
    Look real Good
    Give it a good look. If I remember right those are replaceable bolts not studs that may need drilling if broken. Gaskets used to be available, if not they aren't that hard to make. Leo
  • hot rod hot rod @ 10:14 AM
    Contact this user
    Parts are still available from Vaillant US
    here is the info.
