Forum /
THE MAIN WALL /
non barrier pex on heating system
Post a Reply to this Thread
non barrier pex on heating system (5 Posts)
a foot
will not make a huge diff. but why take the risk.... kpc -
Are they feeling lucky?Class 'A' Gas Fitter - Certified Hydronic Systems Designer - Journeyman Plumber
New EP Manifolds from Uponor
do not have a Oxygen diffusion barrier. These are very nice "Engineered Plastic" manifolds. The "Plastic" had me wondering because I have always heard the Uponor gospel according to non-barrier. I had to press for this answer and their response was that, "its small, relative to the system". That one surprised me a bit. Really, if I am going all out with the non-barrier premise with the DIN4726 rating blah blah blah, you think they could coat their new manifolds with something to prevent oxygen diffusion. (?) I do understand that the DIN4726 rating doesn't state that it is "oxygen impenetrable", it states that it has a rating of so "many mils per hour". If you want to press the issue, if non-barrier tubing is embedded in concrete, that technically should not be exposed and oxygen permeable either. Make sense to anyone else or am I splitting hairs here? Paul -
I agree
Why do something half assed? Might as well build our own manifolds - in fact it'd probably last longer. Some manifolds have finicky parts & O-rings in them that can fail.Class 'A' Gas Fitter - Certified Hydronic Systems Designer - Journeyman Plumber -
non barrier pex on hydronic system
CUSTOMER WAS INQUIRING ABOUT USING A PIECE OF NON OXYGEN BARRIER PEX TUBING IN THE SUPPLY SIDE OF A PIECE OF RADIATION APP 12".WAS WONDERING ABOUT THE IMPLICATIONS INVOLVED WITH AIR ENTERING THE SYSTEM.THANK YOU SO MUCH!!
