Forum /
THE MAIN WALL /
Dual Mod/Con Install Pics
Post a Reply to this Thread
Dual Mod/Con Install Pics (15 Posts)
Thought I try out adding pix to the new site.
Here is a job we are working on now.
Two Buderus GB142's, LLH, Grundfos Alpha pumps. Manifolds to hot water baseboard heat through out, 4 towel warmers in baths, and runtal panel rad. Total 8 zones, 7500 sq.ft second home looking west to the Catskills. -
Trying again.
Could not add another image using the add another image button. Safari Java script error? -
Darn nice looking job Devan!
and yup, posting here is now a we bit of a pain. I typed a respone to a thread yesterday and the security garbage dropped me out and i lost my typing. I said the heck with it since i type with the one finger search and destroy method..but anyways, i digress, you do some really nice pipe work!Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.This post was edited by an admin on August 17, 2009 10:51 PM.
Reason: correct spelling goof -
Whew!
Also security check must be on a timer. Trying to upload an image to the wall, ending up typing in a new code three times before sucess. -
A safe bet
It is a safe bet that this job is a contender if not a sure thing for some System Showcase accolades.
Beautiful work Devan. Is that grey melamine? Very well thought out and I love the piping as it dissapears into the wall. Your concealed wiring is top shelf.
I think I will have to go "Tonya Harding" on you before the System Showcase Awards if I'm to have a chance. :)
Best to you,
Paul -
Thanks Paul
was not really thinking about system showcase awards for this one, but I may have a few other jobs in contention ; ) -
Wire on Pumps?
Are those electric cords hanging on the iso-valves on the system pumps? If so what are they for? -
nice layout
I like the way you offset with the 45's nice work. Great components also.
Yeah, I'm torn on the corded versions of the Grundfos. I like that you don't need to get inside, the pump to wire it, but it limits you to that wire??
hr -
Thanks
Yep, the Grundfos Alpha has a quick connect cord connection.
Downside, you have to use it, I will probably finish up the wiring soon, I just
did not want to cut those cords yet until I made sure they worked ok.
It is pretty cool though when you close off zone valve , and you see the wattage drop as displayed on the pump. -
alpha wiring
Forgive my ignorance, but how does one wire these Alphas to something like a Taco SR?
Thanks.
p.s. gorgeous install!This post was edited by an admin on August 17, 2009 9:03 PM. -
Thank Rob
Is that you NRT.Rob?
Just cut the ends off the leads, then wire as normal into a taco,grundfos,argo or tekmar relay panel. -
no...
Not NRT.Rob. CC.Rob. Gotta update the profile I guess. Thanks. -
Beautiful work my old friend
You are still a master craftsman. It's always a pleasure seeing someone's work that they take pride in!
Rick -
Thanks Rick
Thanks for the kind words Rick. Hope you're doing well.
Peace,
Devan
