The Wall
Forum / THE MAIN WALL / Hydronic Toe Kick Heater Installation
  • Post a Reply to this Thread
    Hydronic Toe Kick Heater Installation (4 Posts)
  • DYIHelp DYIHelp @ 9:46 PM
    Contact this user
    I'm remodeling my kitchen and would like to install Hydronic Toe Kick Heaters under my cabinets. My current heating source is gas forced air.
    I live in a 1600 sf lofted condo with 15' ceilings and I'm always loosing heat.  The Toe Kick heaters would supplement the gfa heating system, and a new bedroom I'm making by putting up a wall.
    Can water lines be install and hooked-up to my current 40 gallon hot water heater, or do I need to purchase a separate hwh system like a boiler, and if so, then my second question is:
    Are very small boilers or steam systems available to attached to the toe kick heaters for condo buildings.  I'm looking at the Myson Heater, but their spec are very vague.
    I will not be doing this work myself.  I'm hiring a contractor, but want to get a head's up so when I inquire, I can understand.
    Thanks...
  • jim lockard jim lockard @ 9:47 AM
    Contact this user
    Kitchen toespace
    Being a victim of Gas forced air myself, I installed electric heat mat under the tile in front of my kitchen cabinets. This heats the tile over a 3 x10 foot area and has made a difference.  A toe space heater using 130 degree or so water from a domestic heater may not give you the kind of heat you need, not to mention all the work involved with a heat exchanger, circulator piping and control. Perhaps an electric toe space heater would suit your application.
  • Dan Holohan Dan Holohan @ 9:50 AM
    Contact this user
    I'm with you, Jim.
    I think that's the best solution to this one. And running the kick heater's water directly form the water heater would be a bad idea because that water would stagnate during the warmer months and could be a source of bacteria. Good call.
    Site Administrator
    dan@heatinghelp.com
    Hug your kids.
  • HDE HDE @ 10:22 AM
    Contact this user
    And
    And don't forget, kickspace heater fans don't kick on till about 130+
