Forum /
THE MAIN WALL /
Skim question
Post a Reply to this Thread
Skim question (5 Posts)
Skim question
I would like to skim my boiler before the heating season starts. It doesn't seem to have a port near the waterline, there is one at the bottom for draining and one at the top for emergency valve. Is there any way to skim without having someone come and make a new tapping at the waterline? It's a 1 year old Burnham Independence.
Thanks! -
under jacket
Under that jacket on the boiler there will surely be a tapping with a plug for skimming. Contact the manufacturer. The jacket usually has knock-outs where tappings are.
TimWorking on steam and hot-water systems isn't rocket science....it's actually much harder. -
Knockouts
Thanks, Tim. I'm only loosely aware of the terminology here. Let's say there is one, and I can punch through it (with a hammer? how do you do that?). Is it something I can thread a standard size value into, or does it require welding or some kind of compound to attach to it?
Thanks -
N/A September 8, 2009 @ 8:49 AM
better let the pros
Better let the pros get the plug out and set up the fittings for you. Then be taught how to do it safety for next time. -
Skim tap
It should have been installed with the new boiler .Get a steam guy tp removed the plug and add the ball valve . The manufacture instruction will give you the location.
