The Wall
Forum / THE MAIN WALL / Old-time plumbers nostalgia question,,,,
  • Post a Reply to this Thread
    Old-time plumbers nostalgia question,,,, (15 Posts)
  • N/A @ 2:26 PM
    What is this stuff?,,,,, it is hard like glass,,,, but soft when heated.
    I have heard what it "was" used for,,,, what`s your thoughts?  ;-)
    No,,,, it`s not the "Blob" in a dormant state :-)
    This post was edited by an admin on October 24, 2009 2:32 PM.
  • bill bill @ 3:53 PM
    Contact this user
    Is it?
    Could it merely be rosin used a sealing wax?
  • bill bill @ 8:28 AM
    Contact this user
    2nd shot
    It's parrafin
  • bill bill @ 6:00 PM
    Contact this user
    How about Bakelite?
    A first synthetic resin whose cousins are ABS and PVC.
  • Jean-David Beyer Jean-David Beyer @ 7:52 PM
    Contact this user
    My high school chemistry
    If I remember correctly, Bakelite is a phenol-formaldehyde thermosetting plastic.
    PVC is a polymer of vinyl chloride, that is, IIRC thermoplastic.
    ABS is a copolymer of styrene and acrylonitrile, also thermospastic.
    So if they are cousins of Bakelite, they are distant cousins.
  • bill bill @ 9:07 PM
    Contact this user
    Leat me get this straight
    You can remember that Bakelite is some Phenothis,  Formathat, Thermo Plasti whatever and God only knows what? Your instructor must have been a close relative of the current Mr. Google.
    Used in the 78's not 45's or 33's I thought it was a toy oven to make a cake with a light bulb.
  • Dave Yates (GrandPAH) Dave Yates (GrandPAH) @ 7:34 PM
    Contact this user
    Rosin
    Used on our cloth strap-wrenches to gain a good grip with polished chrome, brass or gold-plated trim. Showing my age(G).
  • Devan Devan @ 8:59 PM
    Contact this user
    Also used
    in treating wiping cloth, back in the day to wipe a lead joint. Keeps the lead from sticking to the cloth. The few times I attempted to wipe that is what I was taught.
  • N/A @ 11:05 PM
    Nope,,
    although bill was very close,,,,,,,,,,
    JD seems to know everything,, (sorry I forgot his ULTRA),, where`s his input?
    This post was edited by an admin on October 24, 2009 11:15 PM.
  • Jean-David Beyer Jean-David Beyer @ 5:48 AM
    Contact this user
    I guess you were teasing ...
    ... but I do not quite understand. I certainly do not know everything. I know less about heating than any of the professionals here. Would you prefer I post less?
  • Wayco Wayne Wayco Wayne @ 5:54 AM
    Contact this user
    Moon rocks
    Brought back by Apollo astronuats. I'll be interested to when the first McDopnalds opens it 's first franchise there.
  • N/A @ 6:35 PM
    Ok, Ok,,,,,,,
    I don`t really know,,, but I heard it was used as a cheater the old-timers could use on CI drainage piping that had the odd sand- hole.
    The rosin explanation sounds more professional,, but this stuff is hard, and heating-it-up to apply could burn many a fingers,,,,, then again, so has wiping joints!  :-)
  • PaulR PaulR @ 9:12 PM
    Contact this user
    I'm picturing it as a hydronic sweetener for my Delta T...
    Two lumps please :)
  • Lyle {pheloa} Carter Lyle {pheloa} Carter @ 9:21 PM
    Contact this user
    Rosin
    If your lead pot was outdoors ( due to smoke and chance of lead popping) the rosin would be added to the molten lead or wiping solder to make the impurities float to the top.
  • EricAune EricAune @ 8:09 AM
    Contact this user
    Multi-use
    Grandpa used it to clean molten lead, my uncle used it as a thread sealer and a dressing for his strap wrenches.  Other uncle says it worked best to fix a cracked no-hub fitting for an air test.
    I use it as a conversation piece when other plumbers come to the shop.....makes me look like I might not be as wet behind the ears?
    I would not know where to find any so I just use discarded chunks of roofers tar for my (fixable) cracked no-hub fittings and haven't used a strap wrench since I was a second year.
    I like the sweetener idea best.
    "If you don't like change, your going to like irrelevance even less"
