The Wall
Forum / Controls / help with intelidyne controler
  • Post a Reply to this Thread
    help with intelidyne controler (2 Posts)
  • gkratt gkratt @ 12:46 PM
    Contact this user
    i have a honeywell L4081B, dont know which wire to connect the red and yellow off of the control, unit has power
  • dynamic dynamic @ 7:13 PM
    Contact this user
    Wiring help
    Find out which side of the aquastat is the load side. Remove wire, connect yellow to aquastat and then connect red wire to wire that you removed. The load side should be labeled on the wiring schematic on one of the panels of the boiler/furnace.
    This post was edited by an admin on November 15, 2009 7:15 PM.
