The Wall
Forum / THE MAIN WALL / Galvanized pipe, why not a good idea?
  • Post a Reply to this Thread
    Galvanized pipe, why not a good idea? (5 Posts)
  • Al Roethlisberger Al Roethlisberger @ 1:02 PM
    Contact this user
    I've seen it mentioned a few times when someone spots galvanized pipe in a job that it ought to be replaced with regular black steel.  Why is this?
    I have an example where the very top venting "antler" setup in my attic was constructed of 3/4 galvanized, and wonder if this is really a big deal to go replace with black steel?
    Al
    Just a DIY'er trying to learn, and improve and maintain his converted ca 1929 overhead gravity hot water system since there is no one local that can.
  • Ron Jr. Ron Jr. @ 4:35 PM
    Contact this user
    Not sure
    what you mean by " venting antler setup " , but if it's a closed hot water system , I don't see the harm in having galvanized piping .
  • N/A @ 4:36 PM
    Al,,,,,
    I cannot see any reason,,,, leave-it be.
  • Al Roethlisberger Al Roethlisberger @ 5:49 PM
    Contact this user
    Thanks.
    Yes, it is closed hot-water.
    Al
    This post was edited by an admin on November 8, 2009 5:49 PM.
  • hot rod hot rod @ 8:35 PM
    Contact this user
    galvi is a no no
    with glycol, but should be fine on HW.
    Even on a closed loop hydronic I would keep copper and galvi separated by brass or bronze, they seem to not get along well when they butt heads.
    hr.
