The Wall
Forum / THE MAIN WALL / Water storage tank for hot water boiler
  • Post a Reply to this Thread
    Water storage tank for hot water boiler (3 Posts)
  • lplus10 lplus10 @ 5:15 PM
    Contact this user
    Is this a good idea?? I am getting a mix of opinions, mostly that a water storage tank is a waste of money and energy. I have an old Climatrol with 6 large cast iron sleves that I want to replace. It must hold at least 30 gallons of water in the boiler itself. What if I create a separate tank that will be attached to a new hydronic boiler, keep this water temp at 140 degrees, then pump water to the radiators right from the tank as needed? Any opinions?
  • Jamie Hall Jamie Hall @ 6:00 PM
    Contact this user
    Seems to me...
    that you will lose heat from that storage tank -- no matter how good your insulation -- and that you will gain very little in terms of response time.  So why bother?
    Jamie
    Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England.
    Hoffman Equipped System (all original except boiler), Weil-McClain 580, 2.75 gph Carlin, Vapourstat 0.5 -- 6.0 ounces per square inch
  • gerry gerry @ 8:54 AM
    Contact this user
    multifunctional buffer tank
    I like the idea of a buffer tank for hydraulic separation dirt and air separation   there are many reasons and applications to consider the proper use of a buffer tank.   Gerry Alder                  [url=http://www.pmmag.com/Articles/Column/7b4f1edc2471b010VgnVCM100000f932a8c0]http://www.pmmag.com/Articles/Column/7b4f1edc2471b010VgnVCM100000f932a8c0____
