The Wall
Forum / Indoor-Air Quality / Honeywell UV Question
  • Post a Reply to this Thread
    Honeywell UV Question (2 Posts)
  • EddieG EddieG @ 1:11 PM
    Contact this user
    When the bulb is replaced and reset button is pushed. I am getting a flash code and it won't light up. According to part numbers I have the proper replacement bulb. The unit has been in 3 years and this is the 3rd bulb change, no problems prior till now. Thanks for any help in advance. Unit M# UV100E1043                      Bulb# UC100E1006
  • BillW BillW @ 10:27 PM
    Contact this user
    Honeywell UV question
    What is the code saying?  BTW, I am no longer associated with Honeywell, but I will try to help you out.  You also can try [url=http://www.customer.honeywell.com]www.customer.honeywell.com, and follow the prompts.  The site has literature and technical info at no charge. Is there power to the light?  There is a safety device that prevents the bulb from lighting unless it is seated propoerly. DO NOT bypass any of the safety interlocks, looking at one of those lit bulbs even for a second will cause severe and probably irreversible eye damage. Be careful.
