The Wall
Forum / THE MAIN WALL / Closely spaced tees
  • Post a Reply to this Thread
    Closely spaced tees (2 Posts)
  • J_W_P J_W_P @ 8:59 PM
    Contact this user
    Closely spaced tees
    Quick question on using closely spaced tees.  Does it matter which ways the tees face each other?  Can you have the water enter the run and out the branch  in the first tee and the enter the branch and out the run of the second tee? In most of the diagrams I see, the water flows through the runs of both tees and the branches pick up the secondary circuit
    Thanks
    Jim
  • gerry gerry @ 10:10 PM
    Contact this user
    YUP IT MATTERS
    A hydraulic separator  does it better .  closely spaced tees also need straight pipe in and out something like ten times the pipe diameter. Gerry Alder
