The Wall
Forum / Oil Heating / air in oil line
  • Post a Reply to this Thread
    air in oil line (8 Posts)
  • Pin Pin @ 12:09 AM
    Contact this user
    air in oil line
    Recently I been experiencing a weird problem with my oil burner. Whenever the oil tank has approximately 1/4 left, the oil line will get air inside the line between heat cycles. I will have to bleed the air out in order for it to fire. Once the thermostat is satisfied, the boiler shuts off and the next time the thermostat calls for heat, I have to go and bleed again.
    This does not happen when I have more oil in the tank. What could be the problem?
    Thanks!
  • Paul Fredricks Paul Fredricks @ 7:06 AM
    Contact this user
    pin hole
    If the line enters the tank from the top, it could have a pin hole in it down low that's letting the air in. If that's the case you need to replace that piece of line. I suppose it could also be an air leak down the line too, though I'd think that would show up as an oil leak during the off cycle.
  • conway conway @ 1:37 PM
    Contact this user
    same problem
    I have the same problem it seems - I have had this happen a couple of times in the past few days, after the oil reached about 1/4. (Getting filled today - will see if it fixes the problem).
    But my line enters the tank on the bottom, not on top. And I'm pretty sure I don't have an oil leak - my tank is in the basement above ground, and I would smell it if it's leaking.
    Are you saying the line is leaking, or the tank?
  • Paul Fredricks Paul Fredricks @ 2:40 PM
    Contact this user
    not the tank
    If the line comes into the top there can be a pin hole in the line that lets air in once the oil drops to that point. Guess that's not you situation. It may seem obvious, but if air is getting into the line then ... you must have air leaking in :)
    Is the tank situated below the oil burner? Is there an oil safety valve?
    Have the filters been checked lately?
  • conway conway @ 4:30 PM
    Contact this user
    more details
    The tank is above the burner, but the oil line (single line) goes up to the ceiling and crosses the basement (about 35ft) until it drops back down to the boiler.
    There is a safety valve at the tank.
    I checked the big filter - the 1A-25A General filter, and it looked ok. (To my untrained eye). The filter was changed at the beginning of the season.
    I didn't check the filter internal to the pump.
    I actually had the same sort of thing happen at the beginning of the season - every time there was air in the line - but the tank was almost full then. I tracked that problem down to the fact that there was a tech in to tune up the system over the summer, and I think he didn't align the gasket on the General filter well. When I opened the filter and re-sealed it the problems went away. I tried this trick this time again, but it didn't help.
  • Dave Mayer -3 Sons Heating Dave Mayer -3 Sons Heating @ 6:53 AM
    Contact this user
    Air
    Ahh, overhead lines.  You need an oil de-aerator-commonly called a Tiger Loop.  I would first have your technician check for a vacuum leak, then if all is okay install a Tiger Loop.  Good Luck
  • conway conway @ 10:12 AM
    Contact this user
    thanks!
    Thanks guys for your replies!
    So does it make sense that without a 'tiger loop' you'd get air in the system when the oil is low?
  • Coany Coany @ 6:09 AM
    Contact this user
    you need to vacume prime
     close the firomatic at the tank and start the burner
     wait 5 seconds or so and open the bleeder, until it locks out
     quickly close the bleeder before the burner stops spinning completely
    reset the lock out and start the burner, open the bleeder
     hurry over to the tank and open the firomatic at the tank.
    You should hear the high vacum in the line sucking the oil out of the tank.
    hurry back over to the burner and close the bleeder port once you get pure oil /no foam.
     this will force every bit of air trapped in the line out the bleeder port.
     its a great practice every time you prime an overhead line.
    " Do what you can, with what you have, where you are" Teddy Roosevelt
