LG mini split error codes
today i received an error code on my lg mini split unit, could not get local wholesale, distributer or factory support to answer my question today. i am receiving a code flashing between CH and 24 on the indoor unit display, does anyone out there happen to be able to translate this for me i would be greatfull
CH24
A colleague informed me that a CH24 error code indicates the opening of a pressure switch. The code is not specific about whether it is a high pressure switch or a low pressure switch that has opened.
Hope this helps.
LG DUCTLESS HEAT PUMP ERROR CODES
I HAVE 2 UNITS IN "NO COOL" STATUS RIGHT NOW [90 DEG OUTSIDE]:
LMN-095 HVT UNIT IS FLASHING BETWEEN CH AND 61'
LMN-125-HVT IS FLASHING BETWEEN CH AND 09.
BOTH PANEL BREAKERS ARE ON.
CANNOT REACH MY LOCAL CONTRACTOR NOR CAN I LOCATE A SERVICE TECH MANUAL ONLINE. ANYONE HAVE A CLUE ON THIS?
