The Wall
Forum / Oil Heating / Radiator Top not getting hot
  • Post a Reply to this Thread
    Radiator Top not getting hot (7 Posts)
  • marie14 marie14 @ 12:46 PM
    Contact this user
    Old oil furnace.  First floor radiators work perfectly.  When get up to 2nd floor - each bedroom has a radiator, but only the bottom of them are getting hot.  I've bleed the several times, still no luck.  Is there some type of adjustment needed to make on the actual unit in the basement?
  • Al Letellier Al Letellier @ 9:35 AM
    Contact this user
    top of rads not getting hot
    Marie: with an old "beast" like that boiler, I would suggest you contact a heating professional. It may be pressure related or another issue. Best to have someone look at it. Old equipment does not always respond like we might advise and trouble could be waiting at the turn of a screw.
    AL
  • Big Ed Big Ed @ 5:39 PM
    Contact this user
    Bleeding
    When you bleed the radiators , do you end up with water ? If not , you don't have enough system water pressure...i cant read the gauge
    I have enough experience to know , that I dont know it all
    This post was edited by an admin on January 26, 2010 5:42 PM.
  • marie14 marie14 @ 6:25 AM
    Contact this user
    Yes - I always get water out when it bleeds.
  • Hop Hop @ 5:14 PM
    Contact this user
    top not hot
    Is it a gravity system or do you have a circulator pump?
  • Charlie from wmass Charlie from wmass @ 6:43 PM
    Contact this user
    Can we get a couple more pictures?
    one of the side of the boiler and maybe one of from a bit farther back? Are the valves open at the radiators? A picture of them would be good also. There is the find a pro section at the top of the page. Some of us do work on all types of boilers not just steam
  • JStar JStar @ 6:24 AM
    Contact this user
    Radiators.
    Are the supply and return lines both on the bottom of the radiators? Is there a pressure gauge on the boiler (if you can trust it to be accurate)? What does it read?
