The Wall
Forum / THE MAIN WALL / The best pipe dope.
  • Post a Reply to this Thread
    The best pipe dope. (23 Posts)
  • REX REX @ 8:10 PM
    Contact this user
    The best pipe dope.
    Potable water:Teflon tape,Megaloc.
    Non potable water supplys:Blue Block
    Natural Gas: 1/2 - 2" Blue Block,2 1/2 - 4" X-PANDO.
    Steam: 1 - 2" Blue Block,2 1/2 - 6" X-PANDO.
    Hot water heating:Blue Block.
    PVC: NPS adaptors Blue Block, C.O. Teflon tape and dab Megaloc.
    Other than pvc c.o. I do not use teflon on anyother joint.
    So then,all i have on my truck : megaloc,blue block,xpando. What do you use?
  • N/A @ 9:30 PM
    Interesting summation,,,,
    Do I have to ask??, but I will,, which company do you represent?  ;-)
  • Ross Ross @ 9:35 PM
    Contact this user
    Megaloc
    I can't stand Megaloc. I don't think it performs as well as other pipe dopes. It's all about preference
  • Jim Bennett Jim Bennett @ 10:09 PM
    Contact this user
    Rectorseal 5....
    been using it for 30 years.
    Jim Bennett
  • MikeyB MikeyB @ 6:52 AM
    Contact this user
    Pipe Dope
    I like Real-Tuff by Hercules, easy to use, & clean
  • digger digger @ 8:22 AM
    Contact this user
    Rectorseal 5
    I'm with Jim Bennett, Rectorseal 5 for steam and hot water since it bailed me out of a tough situation 20 yrs ago. The contractor I have been working for the last 5 yrs rolls his eyes when I ask for it. He's a Slik Tite guy. He thinks leaks are normal though. Teflon on steam is not allowed in the pharma and nutritional facility we work in. Engineering firm says offgassing at initial start up is toxic.
  • Ross Ross @ 6:52 PM
    Contact this user
    Rectorseal #5
    Yes,  I agree I also like Rectorseal #5.
    I have been also using Tru-Blu by Rectorseal.
  • clammy clammy @ 6:09 AM
    Contact this user
    whitlams blue magic
    i have used most of the pipe dopes that are listed and about 7 years ago i had some black pipe delivered to a job it looked as though it had been pulled out of the hudson river very dirty ,well we leaned and flushed it all and did use it ,when i went to the supply house i busted there balls about the pipe to shut me up they gave me the whole display of whitlam products ,there where telpon based stuff and then there was this dope alled blue magic ,it 's rated for oil ,natural gas ,refregerants and steam ,it seems i use it for just about every thing and don't have leaks easy cleaning also now it's the only dope besides myself in the truck peae and good luck clammy
  • REX REX @ 8:07 AM
    Contact this user
    pipe dope
    Cool,seams everyone has a fav.I used all of the dopes mentioned,its just that after 18 years of mechanical work I have gone full circle. I started being taught pride in workmanship...where nps joints should be as clean as solder joints. As time went by i realised being self employed  its all about speed  performance rather than perfect joints. Nontheless I believe I have found two sealents that make perfact IPS joints,both visually and in performance with little effort. Blue Block along with xpando go on verry smooth and get hard,i really like xpando,though i must say the fact the the joint cant or is verry difficult to remove is a issue. Funny its a bit of a connundrum,to leave a joint where the next guy will be up shitz creak,though you will deff not have leaks. I had a run in with a 1" nps nip on natural gas pipe with xpando on it,i had to use a 3' wrench with a 3' perswader on it to brake it...bent the nip to "SNAP" it loose.Spent an extra hour that I had not figured in the job,could have been worse and cost me more.With this fact in mind I reserve the xpando for joints above 2".My logic is larger pipe i not usually relocated as much,as far a steam goes,my experence with old  headers 2 1/2 and beond do not unscrew...regardless of the dope involved,i usually have to salzal the pipe and make reliefe cut and pean out the piece.  I like the fact you can apply it to the first 5-6 threads and as you tighten it pushes the extra dope foward creating a tuff leak proof and visually pleasing bead on the face of the fitting. The remaning 2-3 threads are clean and un touched. I believe there are other dopes that have the consistancy and setting  I like I havent tried yet,im sure thay work well. My bigest issue with teflon dopes and others that have that thick consisentency is that you cant get the finished joint im lookinf for,thay just dont flow.
  • REX REX @ 5:17 PM
    Contact this user
    PRO DOPE
    Im sure all of you have tryed it...atleast once. I always thought it was a relic for back in the ol days that just stuck around for old farts...i was wrong. The consistancy of pro dope is what im lookin for,it just dosent set like i want. I always had leaks when i used it alone. Well all i can say is,if you have factory pipe/joints  or know how to adjust your dies..and use american pipe and fittings,you wont have a leak...no wick or teflon needed. Unfortunately in the real world pipe and fittings along with threading knolledge is lacking,ergo you have the need for teflon and pipe dope or these dopes that make caveman joints so you can pack the shitz out of it in hopes it wont leak.
    This post was edited by an admin on January 29, 2010 5:18 PM.
  • REX REX @ 5:25 PM
    Contact this user
    pipe dope
    A bit of knowledge,a lot of guys fight about dope....does it lube....or does it seal! The answer is first seal,and yes it does make it easier to make-up. The confusion started because some threaded joints seal them self,the joints we are all used to using dont.
    NPS: needs dope to seal creast and root of thread.
    NPSF: root and thread cut at exact tollerence and mesh deforming them selfs together to make a mechanicaly sealed joint.
    This post was edited by an admin on January 29, 2010 5:27 PM.
  • malp malp @ 8:26 PM
    Contact this user
    high temp rtv
    I couldn't get a radiator air vent to screw in. The threads were stripped. I put a glob of RTV on the vent threads and stuck the vent straight into the stripped hole. No leaks.
  • Supply House Rick Supply House Rick @ 9:31 AM
    Contact this user
    This guy must have
    Invented Blue Block or works for Blue Block or is married to someone who works for Blue Block... hahaha
  • Charlie from wmass Charlie from wmass @ 11:34 AM
    Contact this user
    I use Pro dope
    It works and I like it. Teflon for brass or copper threads. Some time the "old farts" actually know what they are doing. K.I.S.S.
  • KBP&H KBP&H @ 12:35 PM
    Contact this user
    These young kids.
    Not even one vote for old dope and wicking ( string like substance) us old timers started with,,, and I'm only fifty.    Worked for years and never leaked,, Of course, we didn't have all of the inferior fittings and pipe taper we have today,,, How many different nipple threads have you seen in the past 6-7 years, and the european straight thread?....
  • Ron Jr. Ron Jr. @ 6:56 PM
    Contact this user
    Rectorseal
    In conjuction with Teflon is what I've used for the longest time . Just a few wraps on the first threads , then paint the good ol' yellow over the Teflon , and you have a nice clean joint that can be taken apart with relative ease ........ even after decades . Anything over 1 1/4 inch we paint the sealant on the inner threads too . Out of the 4 or 5 different brands we use , Recorseal spreads the easiest when cold also .
    Our supplier doesn't stock Rectorseal anymore so we switched to Pro Dope . I like it , but it's harder to spread when cold , and when it sets it's a bitch to loosen or tighten more . Haven't had a leak using Pro Dope for the year or so we switched . Largest fittings are 2 inch steam .
  • malp malp @ 7:38 PM
    Contact this user
    surging?
    Will reactor seal #5 cause surging in a steam boiler? Oil based pipe dopes are discouraged for closed-loop steam, but since reactor seal is semi-hardening, I wasn't sure if that applied. Thanks
  • Ron Jr. Ron Jr. @ 10:42 AM
    Contact this user
    A good skim and purge
    will get rid of all the excess Rectorseal easily . More easily than the harder setting sealants , imho . That stuff just oozes off the outer joints when the steam first hits it . On the inside I'll bet it doesn't have a chance to adhere to anything and is easily dumped out of the boiler while cleaning . And regardless of what brand sealant you use , every steam boiler will need a thorough cleaning when it's put on line or if there's repairs done to the piping . I'll have to say we had leaks using Rectorseal on steam joints above 2 1/2 inches though  . It might just be too soft a setting sealant for the larger sizes ...........
  • Timco Timco @ 11:47 PM
    Contact this user
    the straight dope
    I use 'Slick Tite' dope, a white thick paste that works well I find. As for tape, I like the new 'Blue Monster'. comes up to 1.5" wide and 3/4" wide...
    Tim
    Working on steam and hot-water systems isn't rocket science....it's actually much harder.
  • Big Ed Big Ed @ 8:18 PM
    Contact this user
    Pass the Dope my Friend
    I use Pro dope and lamp wick (quick wick ) and only apply on the male threads . Teflon tape I only use now a days for packing (since I cant find the wax graphite any more ) ...Old fashion I know but I just hate leaks ...
    I have enough experience to know , that I dont know it all
  • Kal Row Kal Row @ 11:09 AM
    Contact this user
    love blueBlock but..
    better have acetone and paper towles handy
    - every time i use it i get it all over the place - i think i got some on the moon ;)
    - even though i try to just put a bead on the male fitting only 2 threads away from the end - which always gives me a good seal
    - it's just hard to judge if it will or wont drip and if it drips...LOL... and the soap and water they recomend simply doesnt work
  • heatguy heatguy @ 8:24 AM
    Contact this user
    best dope
    rectorseal  # 5  with teflon - leak lock on anything that maybe trouble .its the original blue ,blu block came out when leak-loc plant burned, if you can afford it its the best
  • N/A @ 9:32 AM
    Whitlam blu magic
    is my favorite flavor of dope right now. We used to use No 5 and teflon tape when we did a lot of propane work and a factory guy from algas turned me on to PLS-2 it was lead based and didnt dry in the threads-amazing stuff-then they reformulated it and took the lead out BOO. I also like gasoila.
