The Wall
Forum / Strictly Steam / check valves
  • Post a Reply to this Thread
    check valves (4 Posts)
  • bn bn @ 10:46 PM
    Contact this user
    check valves
    what is the purpose of check valves on hw zones on steam boilers
  • Al Letellier Al Letellier @ 6:38 AM
    Contact this user
    check valves
    They exist to keep the zone from gravity feeding and to help keep the water in the zone
  • bn bn @ 9:00 AM
    Contact this user
    thanks
    does it matter if the check valves are above or below the water line and if they are before or after the purge valves
  • bn bn @ 11:17 AM
    Contact this user
    check valves
    if the entire loop is below the water level are the check  valves necessary? also is it necessary to purge a loop that's below water level? if yes are two purge valves necessary or can the loop have a single purge valve and the boiler it self will function as the discharge valve? thanks
