The Wall
Forum / Suggestions? / Boiler estimate from 1938
  • Post a Reply to this Thread
    Boiler estimate from 1938 (4 Posts)
  • Gary P Gary P @ 9:32 PM
    Contact this user
    Dan,
    I have a customer in Thomaston CT, They have a boiler house that has 3 Bigelow Boilers with Ray oil burners. (The building was once Seth Thomas Clocks, a lot of history in the building) Running on #6 fuel oil. The boilers and burners are in the 1920-1930 era. They are still original and still run. They are steam fire tubeboilers with brick fireboxes. They use the steam for a platting operation and for heating the building. They are the biggest and oldest I have ever seen. I preform service for the company when the boilers go down or need adjustment. Another company does the anual cleaning of the fire tubes. They are currently converting the building to gas unit heaters.
    When I first started servicing the boilers the maintenance man brought me to a file cabinet in the boiler room. He said we had to go to the clasic literature section. There I found a Ray oil burner manuel. I use this for setting up damper linkage and oil pump pressures.
    Anyway. I was at the facility on Friday looking for the Ray Burner manuel and I came across an original copy estimate from the Babcock & Wilcox Co( 85 Liberty ST New York, NY). dated 1938 for boiler repacement with coal firing. It was on onion paper and still in great shape. I had the maintance man make me a photo copy and I have scanned the image and wanted to give you a copy.
    If you are ever up this way I can take you by to see the boiler room.
    I posted this in this section because I didn't know were else to post to.
    Enjoy.
    Gary Pelletier
    Pelletier Mechanical Services
    381 South Main St
    Thomaston, CT 06787
    (860) 283 0316
    gjpelletier@optonline.net
  • Dan Holohan Dan Holohan @ 9:01 PM
    Contact this user
    Wonderful!
    Thanks, Gary. It's now a part of the Library and much appreciated. Thanks.
    http://www.heatinghelp.com/article/127/Contracts-and-Proposals/1610/Babcock-Wilcox-proposal-to-the-Seth-Thomas-Clock-Company-1938
    Site Administrator
    dan@heatinghelp.com
    Hug your kids.
  • Charlie from wmass Charlie from wmass @ 1:35 AM
    Contact this user
    Just wondering on that name
    I loved the line " Attention Mr. A.S. Goodenough" What are the odds of that being a real name. I think I worked beside some guys who should have had that name. Thanks for sharing this blast from the past.
  • Dan Holohan Dan Holohan @ 9:41 AM
    Contact this user
    Made me think of
    Boris Badenough
    Site Administrator
    dan@heatinghelp.com
    Hug your kids.
