The Wall
Forum / Radiant Heating / BRONZE vs STAINLESS STEEL
  • Post a Reply to this Thread
    BRONZE vs STAINLESS STEEL (4 Posts)
  • Vinny_NYH Vinny_NYH @ 8:36 AM
    Contact this user
    My supplier started giving me stainless steel circulators. He told me they are the same as bronze circulators. I suspect this is not true. For domestic water, can I use a stainless steel circulator?
  • EricAune EricAune @ 1:38 PM
    Contact this user
    Stainless is fine for domestic
    Most of the major manufacturers are switching to an all cast iron or stainless casting product line.  This may be in line to comply with the "no lead" requirements but also streamlines their inventory.
    "If you don't like change, your going to like irrelevance even less"
  • markwilo1 markwilo1 @ 8:45 AM
    Contact this user
    markwilo1
    Just remember though many manufacuturers would have you believe differently, not all Stainlesss Steels are created equally and it is not indestrctable.  Many independant studies have proven bronze volutes to have better flow and wear charecteristics vs SS.
  • Radiohead Radiohead @ 10:42 PM
    Contact this user
    Which metal for hydronic heat?
    What metal pump should be used for circulation pumps in a oxygen barrier hydronic floor system..  Mine are currently cast iron....
