The Wall
Forum / Gas Heating / N.G. pipe size
  • Post a Reply to this Thread
    N.G. pipe size (2 Posts)
  • bill bill @ 10:18 PM
    Contact this user
    N.G. pipe size
    Hi, Could you give an explanation on the two pipe size charts. One is for a pressure drop of .3 water and the other is .5, And which one do you use?
  • Tim McElwain Tim McElwain @ 10:29 AM
    Contact this user
    Most use the .3
    you could check with your local gas utility to see what they use. The .5 will give you a little larger margin as to capacity.
