Forum /
Radiant Heating /
radiant floor heat?
Post a Reply to this Thread
radiant floor heat? (4 Posts)
radiant floor heat?
I live in Long Island, NY in a 1930 house and am in the middle of a remodel. Am now thinking of radiant floor heat. Will this work well? I have 2 stories with hardwood floors throughout. I would be putting pex in the joists with the aluminum heat shields. Am concerned over the wood floor though. Will this cause the wood to buckle?
Thanks. -
N/A June 13, 2010 @ 6:54 PM
wood to buckle?
No,, radiant does not add-to humidity.
What you are doing is turning the available floor space into a giant radiator to heat the room above. The lower the floor temp you need(given by the area & H/L required), the better the efficiency you`ll get from the boiler.
Have it engineered for you!
Good Luck, its a great system! ;-)This post was edited by an admin on June 13, 2010 6:57 PM. -
Buckled Floors
What causes floor damage is the lack of doing a radiant heatloss and design. As Dave said. Have one done. Might cost you but is worth every cent."The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price." -
type of wood
Be sure your flooring supplier is aware of radiant heating. Most will recommend using quarter cut wood which will expand vertically, instead of horizontally.
