The Wall
Forum / Gas Heating / Cleaning GB142 Fins
  • Post a Reply to this Thread
    Cleaning GB142 Fins (2 Posts)
  • FB FB @ 5:58 PM
    Contact this user
    Cleaning GB142 Fins
    There are thick white deposits building up between the fins on the bottoms of the heat exchanger tubes of our GB142 boiler.  Is there a cleaning solution that will loosen the deposits without damaging the aluminum of the heat exchanger?  Any suggestions about cleaning are appreciated.  Fred in Lakewood, CO
  • Charlie from wmass Charlie from wmass @ 10:42 AM
    Contact this user
    Is it a leak or has it not had yearly cleanings?
    The owners manual calls for an annual cleaning and a combustion testing. Find a professional familiar with Buderus and they can clean it with mineral oil, this needs to be done according to the manufacturers procedure though.
