The Wall
Forum / Bloopers / Not quite a blooper
  • Post a Reply to this Thread
    Not quite a blooper (3 Posts)
  • Charlie from wmass Charlie from wmass @ 8:35 PM
    Contact this user
    Not quite a blooper
    A relative of mine who shall remain unnamed( no it was not my father) was working on a tract development and had to go back for a leak on the first and second house after finish as there was a hole in the base of the stack in the same spot on both homes. No one was taking credit for the holes either. So on the current house he was roughing in he decided not to drain the stack after the rough in test. The next day judging by the cursing and screaming from next door he found out who was clipping the pipe.
    The electrician was over shooting his bits as he was drilling and kept hitting the pipe. This time he got a bath for his troubles and a tingling sensation as his drill shorted out.
    No one was hurt during this tale but also no more mystery leaks after the houses were finished either.
  • Steamhead Steamhead @ 3:53 PM
    Contact this user
    I bet
    he was always called "Sparky" after that!
    Steam, Vapor & Hot-Water Heating
    Reducing our country's energy consumption, one system at a time.
  • Charlie from wmass Charlie from wmass @ 12:02 AM
    Contact this user
    My Father never met an electrician
    he did or does not call Sparky. I find my self doing the same thing. I am not sure they all take it well though.
