Forum /
Gas Heating /
high efficiency boiler vs regular
Post a Reply to this Thread
high efficiency boiler vs regular (16 Posts)
Hello,
I am planning to convert from oil to gas and I would like to install a baseboard heating.. My goal is to have the most efficient system that will not cost a fortune to install. My house was built around 1925. One of the Plumbers I talked, mentioned that He does not install High Efficiency boilers in the old houses because of the venting requirements. He told me that it will cost thousands $ more to install a high efficiency boiler in the old house.
Is he right or he just do not have an expertise with high efficiency boilers?
Thank you.
Vad -
What are you heating with now?
Most efficient is good but is it most efficient for the dollar or full out squeeze every drop of heat from your fuel? Are you planning on sealing up your building envelope as well? New windows, insulation, new doors?Cost is what you spend , value is what you get. -
Yes, I am planning to seal my house.I am looking for the combination of a right price for the installation and boiler and I would prefer to have the efficient boiler.
From the other side if to by the efficient boiler and install it cost me much more than to buy and install a regular one (~81 -82%), I will install the regular one.
Much more I mean that it will take more than 3-4 years till it pays for itself.
For info, I am heating with an oil and furnace (2nd floor), steam (1st floor). I want to have gas and baseboard heating instead on both floors and basement.
Thank you,
Vadim -
If you are going to remove all of the
equipment and start from scratch it can get very expensive. How old is the equipment you now have? -
continue
I understand this, However I want to get read from the oil tank in the middle of the baisment and from the other related equipment.
I would like to get an advise regarding if it worth to install a high efficiency boiler in the old house or not.
I would appreciate your answers.
Thank you
Vad -
Replacing old oil boiler with high efficiency gas boiler.
I am afraid I will be comparing apples with oranges here, but here is one datapoint for you.
I replaced an about 55 year old GE oil-fired boiler with a W-M Ultra 3 unit.
This was an about 55 year old 1100 sq. ft. Cape Cod type house in New Jersey (700 sq. ft downstairs, 400 sq ft upstairs).
The old GE boiler is on pages 11 and 12 of this manual:
http://www.heatinghelp.com/files/articles/1025/177.pdf
Page 10 of that manual, for a similar steam boiler, will give you a general idea how it worked.
I made the change in May 2009, after the end of the heating system here, although I replaced an electric hot water heater with an indirect-fired one from the new boiler at the same time. I also had it converted from a poorly balanced one-zone system to a two zone system, and replaced the two convectors upstairs that contained a 3 foot piece of baseboard in each, with 14 feet of Slant/Fin baseboard in each so I could run lower temperatures up there. So we really are comparing apples and oranges.To make comparisons worse, I have no idea whether winter last year was warmer or colder than the year before, and, knowing I was removing the oil tank, I did not order oil to fill up the tank so I do not know how much oil I used.
What I do know is that my gas bill for the year I had the new boiler was less than the oil bills I used to get. The comfort is greater. The boiler is next to noiseless (I cannot hear it in the house; with the old boiler I could hear the burner (first GE, later Beckett) and an old 3-part circulator). And to make price comparisons more difficult, in those days, oil prices per gallon always went up, and so far, gas prices have been going down (how long that will go on is anybody's guess).
With all the extra heat emission upstairs, the outdoor reset on the new boiler, and the condensing I get almost all the time (some of the time heating hot water gets very little condensing), my guess is that I do get about 93% efficiency from that boiler. I read that the most that can be expected from a non-condensing boiler is about 87%, so it is up to you to decide if the extra 6% efficiency is worth it to you. I am biased in favor of efficiency, so I went with the higher efficiency unit. I have no idea what the payback interval will be. I hope the new boiler lasts past the end of the payback interval, though. Or past me (I am 72), because I do not want to replace it.
My house has its walls solid foam, except for the kitchen that is fibreglass. The ceilings upstairs are 6 to 9" fiberglass. The windows are High-E Marvin windows. But I have had no blower test done to see about leaks. The easy leaks are fixed, but if they did not put enough fiberglass around the windows when they were replaced, I do not know that. -
Why not
run steam to the second floor and install a hot-water loop for the basement that runs off the steam boiler? That would be your least invasive way to go. Steam can run off either fuel.Steam, Vapor & Hot-Water Heating
Reducing our country's energy consumption, one system at a time. -
Thank you for your proposal. I do not think it is a good way to go for my case
since I still need to change a boiler. It is too small for both floors. To run steam to the second floor is more invasive compared to hot water pipes. One of the contractors told me that I am going to ruin the house if I do this. -
Actually it's less invasive
since you only have to run one pipe to each radiator. Was the second floor originally piped for steam?Steam, Vapor & Hot-Water Heating
new gas boiler
Last October I took out old 33 year old cast iron oil boiler and went to High efficiency Triangle tube Prestige Excellence PE110 95% AFUE nat gas boiler with built in stainless steel indirect water heater. last year oil would have cost me $2100 and my nat gas cost for the year is going to be about $980.00 big time savings. I have older house close to 100 years old will be putting in more insulation and should be able to lower heating cost some more. If I were you I would go high efficiency gas boiler and install high out copper baseboard and put in as much baseboard as possible so you can run the water temp as low as possible. Depending where you live and how much your budget for this project you could get used cast iron radiators and install them. they heat great even at low water temps and sill look great when cleaned up and painted. regular gas boiler do not have the federal tax credit of 30% up to $1500 like the high efficiency boilers do. the state of Pennsylvania was just giving a $1000 cash rebate on top of the federal tax credit. venting of high efficiency boilers can be hard but if you can get 3" PVC pipe down your old chimney and there is nothing else being vented into the chimney that is one way to vent the Triangle Tube Prestige boilers and fresh air can be pulled in from another source. Just find a good HVAC contractor in your area that has installed these boilers and they can tell you if you can vent the boiler without problems. Go with the highest efficiency boiler you can afford the cost of energy is going any where but down -
Thank you for reply. From reading on the Internet,
I found that High Efficiency boilers (95% and up) require much more maintanance compared with cast iron boilers. Electronic parts brake often and they can be very expensive. The money I safe because of the high efficiency I will spend for the maintenance.
From my Gas company, I have about 50% rebate for Burnham Alpine boilers.
Since you already mentioned about venting of such boilers, can I ask you a question?
You described that I can use 3'' PVC pipe in the chimney. You mentioned that fresh air can be pulled from another source. Another source can be a hole drilled in the wall close to the basement?
I wanted to install 85% efficient cast iron boiler Burnham ES2, But it requires chimney relining. Do you think it is possible just to attach a pipe (PVC or steel) to the boiler. The length of the pipe can be equal to the length of the chimoing to workney. Is this going to work or not? I attach a manual for the boiler ES2.
Thank you alot
Vad
Scary
Read the manual..NO! NO! NO! to your vent question.
I have to agree with all the guys. A high efficiency boiler requires no more maintenance than any other boiler. You speak of the ES2. What would you consider this boiler? I would consider it high efficiency. With the IQ package I can pop in an outdoor reset control module, display screen with diagnostics, return 110 degrees back to the boiler and low stack temps. Might not be a Mod/Con but has the ability to provide energy efficiency above any other non condensing gas cast iron boiler on the market today. Still need to line that chimmney though."The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price." -
I am thinking that maybe it will be more cost effective
to bue Series 3 Burnham and pay full price (gas company do not give any rebates on it) and not to reline the chimney. As for as I understand Series 3 can work with old chimney. Am I correct? Does the Series 3 offers the same advantages as ES2 boiler?
I only see that it is 1% less efficient. IQ package for ES2 comes with the boiler or I have to buy it separately? Same IQ packages can be used with Series 3?
I am still deciding which one to use. High efficiency boiler can be the option as well after reading other posts.
Thank you,
Vad -
"regular" boilers also need maintenance
The regular boilers are now electronic controls and are supposed to be maintained every year. It is in the owners manual. I respect your choice but the logic is not based on fact, just myth and legend. My statement is a reflection of those you got your information from not you as a consumer.Cost is what you spend , value is what you get. -
As someone who has been
in the gas heating business over 50 years I can tell you that all systems require annual maintenance and that will never change.
Also all boilers and furnaces today are mid or high efficiency so no matter what you purchase they all have electronic components and require a very well trained technician to service them. That is why i have a training school to do that.
I would look into many things along with a new heating system including new windows and insulation.This post was edited by an admin on August 30, 2010 9:47 PM. -
high efficiency vs regular gas boiler
If you install a Triangle Tube Prestige Solo or Prestige Excellence you can get a 5 or 10 year parts and labor warranty. this warranty does not cover annual inspection and cleaning of the boiler but if any part breaks for up to 10 years you are covered for the part and labor to replace it. get a quote on the triangle tube boiler and see how much a professional heating contractor in your area will charge you for the extended warranty.
