The Wall
Forum / THE MAIN WALL / Grundfos isolation flanges
  • Post a Reply to this Thread
    Grundfos isolation flanges (11 Posts)
  • Gordan Gordan @ 9:14 AM
    Contact this user
    Any feedback, good or bad? These are the no-handle, screwdriver operated ones, where the flange piece slips over the back of the valve. The screwdriver operation appeals to me more than having a handle that you wind up having to remove.
  • HomeDepotEmployee HomeDepotEmployee @ 9:37 AM
    Contact this user
    Old Stock
    If you came across the screwdriver slot flange sets, they are old stock.
    Once Webstone and many others introduced isolation flanges kits, some with checks, the ones from Grundfos introduced back in the '80's became obsolete. They were 3X the price and contractors preferred handles.
  • Gordan Gordan @ 9:49 AM
    Contact this user
    Yep, kinda figured
    If I prefer the slot type, any reason not to stock up on them? Being old stock, they're not 3x the price any more...
  • N/A @ 9:58 AM
    I prefer handles,
    as HDE points-out, but if you can get slotted/allen key type they are OK.
    PS- Use the allen key because over time they will get very hard to turn with the slot. ;-)
  • Slimpickins Slimpickins @ 11:04 AM
    Contact this user
    exercise is good
    With this type of flange set, its always good to exercise (open and close) a few times when you're out doing your annual servicing. This will keep them loose so they won't freeze  in the open position.16
  • Gordan Gordan @ 11:10 AM
    Contact this user
    Ok, handles it is. :-)
    Aesthetic concerns do not trump long-term performance.
  • Jean-David Beyer Jean-David Beyer @ 11:58 AM
    Contact this user
    But what about homeowners like me...
    While perhaps I can be trusted to know what the handles are for, and that almost all of them should be full on, how would you prevent an ignorant homeowner from turning them, perhaps in a dangerous way?
  • Gordan Gordan @ 12:08 PM
    Contact this user
    That's easy...
    Just remove the homeowner's hands.
    Or the handles on the valves, if you must...
  • hot rod hot rod @ 10:20 AM
    Contact this user
    they all seize up
    after time. I've twisted the stem off the handle type also. Generally it's not the valve but the quality of the system fluid, that causes them to seize up.
    A little system cleaner, then a hydronic conditioner helps a bunch. Better for all control valves, zone valves, and pump bearings, etc.
    hr
  • Bob Bona Bob Bona @ 12:50 PM
    Contact this user
    don't go there
    The shafts will get sticky/seized and the slots will chew out. Go with handles.
  • World Plumber World Plumber @ 12:02 AM
    Contact this user
    Go wit the handles
    With time the slots and allen hex get stripped out and they become inoperable.
