The Wall
Forum / THE MAIN WALL / Solar melt down
  • Post a Reply to this Thread
    Solar melt down (12 Posts)
  • Paul Pollets Paul Pollets @ 1:23 PM
    Contact this user
    Solar melt down
    The Imcolok 3/4" wall neoprene insulation melted between the time we climbed down the roof after installing the 30 tubes to start up the pump module. (Less than 7 minutes) The collector was at 260 F. The system stabilized within 10 minutes at 115 at top of collector. The system can be seen in the Solar category.
  • Mark Eatherton Mark Eatherton @ 1:59 PM
    Contact this user
    Hot, Hot HOT!!!
    Melted my share of that stuff. Have since resorted to real rubber insulation (Donkey u know what). It gets a little crisp on the inside, but doesn't melt through like that other stuff does. Has to be protected from UV degradation (painted).
    7 minutes eh...
    ME
    It's not so much a case of "You got what you paid for", as it is a matter of "You DIDN'T get what you DIDN'T pay for, and you're NOT going to get what you thought you were in the way of comfort". Borrowed from Heatboy.
  • Paul Rohrs Paul Rohrs @ 2:02 PM
    Contact this user
    Propress
    Hey Paul,
    Are using the Propress fittings with the FKM seal?
    Paul
  • Paul Pollets Paul Pollets @ 7:27 PM
    Contact this user
    ProPress
    The fittings are ProPress...nver had a problem with any leaks on glycol.based systems.
  • Paul Pollets Paul Pollets @ 7:28 PM
    Contact this user
    Insulation
    I had some 1" wall fiberglass at the shop with some Zeston cover.  No worries for meltdown now.
  • pipe4zen pipe4zen @ 7:58 PM
    Contact this user
    HT insulation
    Imcolock and others also make hi-temp insulation. I special ordered
    some for my solar piping 3 1/2 years later , still looks good.
    Contact this user
    HT insulation
  • hot rod hot rod @ 8:27 PM
    Contact this user
    XHT
    extreme high temperature insulation is now available from some brands
    Armacell has a UT (ultra temperature) UT SolaFlex product out now. Not for the faint of pocketbox!
    Fiberglass works, keep it dry.
    hr
  • TonyS TonyS @ 10:27 PM
    Contact this user
    Aeroflex
    This stuff works great and is reasonably priced. I use the stuff with the lap seal, it is uv protected and good for 300 f continuous. once you stick the lap over the seam it never comes off!!
    http://www.aeroflexusa.com/products/aerocel_epdm/
  • hot rod hot rod @ 9:50 PM
    Contact this user
    EPDM rubber based insulation
    is comfortable to about 150C @ 300F. Flat plate collectors stagnate above that, evac tube WAY above that.
    Once the rubber turns crunchy the insulative value is about gone.
    New solar insulation options include fleece, mineral wool, polyurethane,, polyolfins, silicone, and high tech aerospace products like Aerogel.
    There are a bunch of low quality solar insulated tube sets on the market. They claim to be EPDM, but in fact are a very low EPDM %, blend. We have tested some solar products that harden and crumble at 200F! Still others that turn to goo at 250F.
    A good solar insulation needs the temperature rating, and also has to be water tight when exposed to outdoor conditions.
    hr
  • Ross Ross @ 9:08 AM
    Contact this user
    Mineral Wool
    What about mineral wool for insulation? It doesn't get ruined when wet, and is suitable for steam heating temperatures. Just curious. Thanks!
  • hot rod hot rod @ 9:48 AM
    Contact this user
    sure, mineral wool works
    it is used in a lot of flat plate collectors still. It needs to be dry, of course.
    hr
