Uponor Manifold & Brain Cramp!
I installed an Uponor manifold this Spring during a remodel project and it is now time to tie my Pex supply & return into it. The problem is I cannot rememeber which part of the manifold is the supply and which is the return! It is a vaveless & the other half has balancing valves.
Would appreciate your help!!
Valves...
are usually on the return manifold.
ME
It's not so much a case of "You got what you paid for", as it is a matter of "You DIDN'T get what you DIDN'T pay for, and you're NOT going to get what you thought you were in the way of comfort". Borrowed from Heatboy.
which manifold?
The newer EP manifolds have flow meters on the supply, the caps are the return, remove caps for actuatores if using.
