Forum /
Oil Heating /
Oil Heater No heat but it is burning oil
Post a Reply to this Thread
Oil Heater No heat but it is burning oil (5 Posts)
My oil heater set up to heat the hot water while I have an electric water heater to provide the hot water . Since my oil burner does not have any switch to turn off, I used the ER to turn off the oil burner. Right now it is winter, I turned on the oil burner, I can see the water come out the oil burner is hot. I can also hear the combustive sound come out often. But I do not know why it did not heat up the house even though I turn thermostat really high. Thx. -
oil burning with no heat
Frances, from your description, it sounds like you may have an air bound system. IF it has been idle all summer, there may have been some air get into the system. The first thing to check is the pressure to make sure the system is pressurized...usually 12-15 pounds on the gauge.
You should call in a heating professional to look things over for you and to make the necessary adjustments. Do not attempt yourself if you do not have the know how or experience to do so. -
The circulator
pump may not be working, may have ceased from sitting for the summer/ or if its an older pump the drive coupling may be broken. If you have zone valves they may not be opening...post some pics of the system as it could be many many things -
pump may have ceased from sitting for the summer
The controller on my boiler has a feature that can be enabled that operates each circulator for 10 seconds after 48 hours of inactivity to prevent this from happening. Other boilers may also have this capability. On mine, it is enabled by the settings of the controller. -
solution
Thanks. It ended up found out the switch for electricity was not turn on.
