The Wall
Forum / Indoor-Air Quality / Humidification in space pak vs stand alone
  • Post a Reply to this Thread
    Humidification in space pak vs stand alone (2 Posts)
  • Tdlsdc Tdlsdc @ 8:32 AM
    Contact this user
    I've got a unico space pak type ac unit and air handler in my insulated attic in Chicago. Does anyone have a preference for a steam unit in that air handler vs a stand alone through the wall stream unit? Any issues w mold in the space pak high velocity tubing?
  • BillW BillW @ 8:25 PM
    Contact this user
    Steam humidifier
    The TruSteam humidifier that Honeywell makes can be mounted remotely, and connected to the supply trunk.  The hose is insulated, and the unit can be up to 20 feet away.  It reqires a drain, water supply and an elecric hookup that varies by unit capacity.  These are available from your heating contractor, and are not sold at retail outlets as far as I know.  I hope this helps.
