The Wall
Forum / Oil Heating / Buderus G115 / Rello F5 - frequent relight
  • Post a Reply to this Thread
    Buderus G115 / Rello F5 - frequent relight (6 Posts)
  • Jbresee Jbresee @ 7:11 AM
    Contact this user
    Hi,
    I've got an intermittent problem with the burner lighting, running a couple of seconds, and re-lighting. As a part of the annual cleaning, I replaced the filter, screen and nozzle, cleaned the CAD eye, and bled the line.
    The restarts don't trip the burner reset.
    My thinking is that I've got an issue with either pump pressure (pump failure) or something restricting oil flow (gunk in the bottom of the tank). I have to run out an pick up an adapter for my gauge to test the pump pressure.
    Do you guys have any other thoughts on this? Obviously, I'm new to the Riello.
    Thanks,
    Jim
  • add add @ 6:11 PM
    Contact this user
    the riello burner
    rarely goes bad,i won't just check the pump psi just yet.you probaly need to bleed it better the riello is very tricky. i reccomend a pro.i also reccomend to be gentle with it when you work on it.
  • SLO-115 SLO-115 @ 1:14 PM
    Contact this user
    thats common
    with the reillo. Usally cad cell related, no a problem with the cell but light. As the burner gets older the blaste tube gets darker it loses its shine. Therefore the light from the flame doesnt reflect back to the cad cell as well. 2 things to do
    1)clean the blast tube with some emery cloth also clean and shine up the electrodes, and the assembly plates.
    2)paint her, white paint job inside the blast tube, you dont need to worry about it melting off as theres no heat in there. This will really help reflect light back to the cad cell.
    Its tough with the reillo as yoju cant take a resistance reading of the cell when the burner is running. If this does;nt catch it i would spend some time looking at the pump coil. Or too much air , double check everything, turbulator, air , pump pressure. Reillo's are awsome and dont usally give any problems , but when they do look out!
  • jimbresee jimbresee @ 9:29 AM
    Contact this user
    Thanks!
    Thanks for the feedback!
    A flakey reading from the CAD cell or air in the line both make a lot of sense.
    I will re-bleed the lines and really clean the area around the nozzle and see if that clears up the frequent re-lighting issues.
    Thanks again for the replies.
    Jim
  • add add @ 7:01 PM
    Contact this user
    if you have
    2 oil lines more than likely you do not have air in the lines.more than likely i would check all the contact under the primary control.sometimes when you remove the primary control on this burner the contacts get bended when you want to have them all lined up before you slide the control back in.
  • meplumber meplumber @ 9:00 PM
    Contact this user
    I have seen this before.
    Check the Oil Valve solenoid.  If the coil is not all the way seated, the valve stem "floats" causing intermittent oil delivery.
    Not saying that this is whats happening, but more likely that a pump problem.  Those burners are bullet proof.
