CLEANING THE COIL
Any one ever cleaned the coil on a heat trans ssu superstore indrect ?? alittle help
no I have not.
the coil is not removable in that is it? If you need to I guess 5 gallons of "sizzle" and drain the tank dry and pour it in through the Vacuum breaker port with a funnel. then let it soay and flush it really well.
