Forum /
THE MAIN WALL /
GAS DETECTORS
Post a Reply to this Thread
GAS DETECTORS (5 Posts)
GAS DETECTORS
WHICH GAS DETECTOR WOULD NOT GIVE A FALSE READING WHEN THERE IS PIPE DOPE PRESENT AT THE JOINTS. DOES ANYONE KNOW.
SOAP AND WATER WORK WELL BUT I 'LL LIKE TO BUY AN ELECTRONIC TESTER
THANKS -
no such thing
All gas detectors will alert when a petroleum based pipe dope is used. For gas you need to use a product without petroleum. There are a lot of Teflon based dopes out there but I've been using Megaloc for years with great results. Also a heads up, typing in caps is bad on-line etiquette, it's considered yelling.This post was edited by an admin on January 26, 2011 1:20 PM. -
Gas Detectors
A gas detector will show the general idea of the location of a leak . I have one sitting in the truck for years ... I find a good bubble solution like Big Blue with show you the slightest leak ... Far better then soapy water...I have enough experience to know , that I dont know it allThis post was edited by an admin on January 26, 2011 2:42 PM. -
Gas detectors are designed
to be used as a safety device to measure percent of gas in an environment. With natural gas the Upper (14.5 % gas) and Lower explosive limits (4.5% gas) are measurable with the detector. Or for LP it is 2.15 to 9.6%. Any reading above 2% you should evacuate the building and call the utility or propane company. NEVER enter a building were you smell gas unless you can determine % of gas with a good detector. Any thing less than 2% proceed with caution ventilating the area and make sure all sources of ignition are secure. An easy way to remember is above 2% you evacuate below you ventilate.
They are not the best for pinpointing gas leaks. Better to either do a test using the test dial on the meter with all pilots shut off to show that there actually is a leak.There would be movement of the 1/2 foot test dial. Or another method is by using a U gauge (manometer) and see if there is a pressure drop. To finally pinpoint leaks is to use non-corrosive soap and water. -
GAS
Thank you all
