The Wall
Forum / THE MAIN WALL / Small service vacuums and compressors.......
  • Post a Reply to this Thread
    Small service vacuums and compressors....... (6 Posts)
  • Small service vacuums and compressors.......
    Any suggestions for a small vacuum and compressor for typical service call cleanings on boilers?  I don't do any oil boilers, so mainly what I need to clean up is dust and rust.  The 3 1/2 gallon Sid Harvey Soot Master is simply too bulky and I am looking at equipping smaller vehicles for service work....no vans or pick ups.  I have a small hot dog compressor, but smaller and lighter would be better yet.
    The Steam Whisperer (Formerly Boilerpro)
    Chicago's Steam Heating Expert
    Noisy Radiators are a Cry for Help
  • Charlie from wmass Charlie from wmass @ 9:55 AM
    Contact this user
    For light clean up I like the
    8 gallon shop vac from True Value hardware. It has a choice of fine filter bags and is large enough to clean a decent size mess. Small compressor I use a cheap one fron Harbor freight, it is a mini twin tank. The good oil-less compressors do not seem to take bouncing around in a truck. The one I have is oil lubed. I use a Tacoma with a cap for most work but I actually would really prefer having a cab forward with a plain box for the boiler work. My truck is fine 80% of the time. It is that 20% that is a drag.
  • Looking for smaller....
    I have a 3 1/2 gallon Sid Harvey unit, but want something smaller.
  • rlaggren rlaggren @ 11:01 PM
    Contact this user
    Some people talking about compressors here...
    http://www.finehomebuilding.com/item/11339/in-search-of-a-quiet-air-compressor
    FWIW, before I found a deal I couldn't turn down I was figuring on the Senco.
    Rufus
    disclaimer - I'm a plumber, not a heating pro.
  • World Plumber World Plumber @ 9:49 PM
    Contact this user
    Shopvac
    Shop-vac makes a little 1 gallon unit. I like it for clean the gas boilers and small pickup jobs. I use my soot vac for oil. If I'm doing a job where I'll be making a mess. I put my 5 gallon Shop-Vac on the truck.
  • Glen Glen @ 7:32 AM
    Contact this user
    buy cheap
    and shed no tears when they pack it in. I tried the soot master - poor track record and longevity. No oil? Regardless the fine dusts and aldehydes still kick the slats out of the vacuum motor and bearings.
