The Wall
Forum / THE MAIN WALL / Hago Nozzles are ES the same as B?
  • Post a Reply to this Thread
    Hago Nozzles are ES the same as B? (3 Posts)
  • cwilliams2000 cwilliams2000 @ 6:44 PM
    Contact this user
    Not sure about this, but are there Hago B nozzles any longer? Are B and ES (Extra Solid) the same? The specs call for a Hago 1.10B and my supplier had Hago 1.10ES. Thank you
  • Al Letellier Al Letellier @ 9:03 PM
    Contact this user
    hago ES
    The Hago ES is a solid core nozzle but is not necessarily the same. Some burners simply like some nozzles more than others. Try it and set up your burner wtih instruments and you will know if it is "the same" in a hurry.
  • cwilliams2000 cwilliams2000 @ 6:27 PM
    Contact this user
    The Answer
    Hago does manufacture B and ES nozzles. The ES are specified for specific applications and do have a different pattern than the B type which focus more fuel towards the center than the ES. I contacted them since no one had answered yet so hope this helps if you are looking.
