The Wall
Forum / Oil Heating / vibration isolator pads
  • Post a Reply to this Thread
    vibration isolator pads (2 Posts)
  • Bing Bing @ 9:06 AM
    Contact this user
    My neighbor's new Crown (Kingston ?) oil furnace installed in their basement in causing a vibration hum in the structure of my home - we have adjoining brick houses. Would isolator pads under the boiler and between the piping and the boiler help to isolate the vibration noise? If so, what are some good brands?
    Thank you.
    Bing
  • Big Ed Big Ed @ 10:00 AM
    Contact this user
    Vibration Noise
    Could not hurt, but is it the cause of the noise ? The best way to find the source I found is just hold and move different pipes and objects until the noise stops . Could be the oil line as well . Most likely it's a loose pipe just barely touching a beam or wall . Tends to act like a speaker .
    I have enough experience to know , that I dont know it all
