themal transfer topo map of us
Done quite a bit of Geo-exchange heat pump systems using coil in trench method for heat transfer. Would like to know if there is a map out there of the US that shows specific thermal transfer properties of soils based on location. I know its a long shot, but rule of thumb numbers sometimes require a large margin of error on the safe side that can make these systems non-competitive on length of payback.
Maybe
Don't know if this site is what you are looking for but it may have some helpful info.
http://www.geo4va.vt.edu/A1/A1.htm
Jerry
This post was edited by an admin on April 5, 2011 4:20 PM.
